Hello, the function is still in development, how can you dynamically substitute a value from a column in Lookup? If the column name is selected from the dropdown list.
Hi @BiBo.
Could you explain what you mean by “dynamically substitute a value from a column in Lookup”? Is something like the following example what you were looking for?
People.lookupOne(Email=$Work_Email)
George
Thank you for response.
Example in Grist
Something similar to selecting values ​​from a matrix.
I think getattr
is what you’re looking for.
Here’s an example of a formula that I believe produces the results you’re expecting:
record = Table2.lookupOne(id=$Selector)
getattr(record, $Selector.Column)
George
It works! Although I don’t understand how it works.
I have the feeling this topic could be really interesting but I don’t understand the question or the answer
Care to elaborate and give an example with some explanation?
Thanks !
Yes I know the function, I just did not understand your initial question… as well as @georgegevoian’s answer actually
