@Tazwar_Belal1 the error message is saying that no methods for authentication have been found. Could you try removing the spaces after the = sign in gristParameters, in the GOOGLE_CLIENT_ID and GOOGLE_CLIENT_SECRET lines? And then try running restartGrist in the way described here:
Just to rule out that possibility. If any errors are issued when calling restartGrist, that could be helpful in getting to the root cause.
Yep I actually removed the spacing and it seems like I am having issues with SSL because when I try using my domain it keeps giving me the error that the access is blocked:
The access blocked is because I did not put my domain inside the gristParameters file and I was told to use the public http link however I can use that particular link within my google redirect URL hence the access blocked.
I am guessing this can be fixed if I can get an ssl certificate from Let’s Encrypt because this is what the log is showing thus far:
Can you say more here about the domain setup? Are you saying you cannot use a https://tazdomain.com/… redirect within google auth? Or is there another domain involved?
The issue is I can’t get the page to load up even with my domain pointing to the ip address of the ec2 on aws. I got rid of the spaces as well so I am not too sure what the issue from then on.
From the gristParameters file I tried leaving the URL part empty and it gave me a public url to use but with that one I keep getting the “Access Blocked” message and that is because I can’t put that url inside the redirect url so I am just trying to go back to using my https://tazdomain.com instead.
I was able to make it work now! The main problem was just making 5 reconnects with an invalid domain and I had to wait an hour to re-run the hosted website.
