How can I reference data across documents and workspaces?
I have 4 workspaces, as I divide between my clients.
In my master workspace, I use common data (eg Country list).
How can I use that data as Reference in a document in a different workspace?
Currently I maintain the same table copied in different workspaces/documents, but would be good to have a single source of truth to avoid mistakes.
You can’t reference across documents. What you really need is to combine your documents into one and use Access Rules to hide sensitive data from the appropriate clients.
Thanks.
Understand this would be the way to go, but the business risk of exposing data from one client to another because of a misconfigured access rule is too great. In that case, I prefer continuing with my approach, where the risk is more limited (eg data not consistent across reference tables).
I’ll think about it… perhaps I can just run a script regularly to ensure data is the same in my reference tables in each workspace (perhaps the sync_tables method could be useful, haven’t played with it yet)
Has anything changed in terms of this capability? I’d love to be able to set up common tables in a single location that can be used in other documents.
haven´t tried it yet, but only thing I guess can be done by now is to set automations with n8n or zapier etc, to keep some reference tables the same across multiple documents.
just TEST and TEST and TEST. First duplicate the document, replace with fake data then test.
DOn´t forget to test the EXPORTS too (like in Excel).
every row in ALL of your tables will need a reference to a company and all users will need to refer to that company
if a user is not configured to a specific company, he should see NOTHING.
