I am just setting up a self-hosted instance of image: gristlabs/grist:latest and would like to add a docker healthcheck, but the image does not seem to contain curl, wget or even nc so does anyone have any idea how else to add a healthcheck?
Hmm good point, we should probably throw in curl as a convenience. There should be a way to do it with node, which is available, perhaps something like:
That should return a non-zero status if the get() throws an error or if it returns a result with a non-200 status code. It is a bit verbose though! Would definitely accept a PR adding curl to the regular docker image:
Sorry, I canβt help with PRs, I have no idea how that works but based on your code here is a sample workign healthcheck which can be added to a docker-compose.yml file:
