How to add a map only from zip code?
How to add a map only from zip code, without coordinates?
Best
The current Mapping Locations template lets you geocode from either coordinates or city + state.
I’ve found that it also works with city + country, such as Paris, France.
Simply enter the city + state (or city + country) then toggle the geocode switch.
It does not work for zipcodes. You’d have to modify the custom widget in that case. @paul-grist would be more useful when it comes to customizing the map custom widget.
