How to add Python libs in Grist Desktop?
Hello everyone I need to add a word lemmatization library to Grist Desktop. Is it possible? If so, how do I do it?
I use Windows x64 version.
Thanks!
Somebody help me please!
Unfortunately, this is not currently possible, at least not easily.
The usual advice for adding Python libraries is to rebuild a self-hosted version of Grist with the extra libraries.
In the case of desktop, that would mean rebuilding a version of Grist desktop with the extra libraries, which most users are not equipped to do. But if you are, the advice is as above, and you would have to rebuild your own version of Grist Desktop from the Github sources.
On desktop, it might be nice to be able to point Grist towards a system python interpreter, if this would be possible (not sure if the app has it embedded or is built against a specific API version, for example).
