anefta
August 27, 2021, 9:19am
1
Let’s say I have a Choices Column with default options A,B,C.
What I want is to let the user to add manually new choices like D,E,Z etc.
Basically, what I am asking is how to auto-add user values to Choices list that already exist.
How to achieve that?
Best
There is a “+” item at the end of the choices when a user enters a new choice for this purpose, would that work? Another possibility is that if you convert the column to type Text, and then back to Choice or ChoiceList, the list of choices will be rebuilt (but you’d lose any color selection).
anefta
August 27, 2021, 5:41pm
3
Thank you for this info.
I use a Reference List. There is no “+” icon, so how to do that?
Can you try typing something in? A “+” should appear as soon as you type something that doesn’t match an existing possibility.
anefta
August 27, 2021, 5:47pm
5
Thank you so much! It works!
Shrey
April 17, 2025, 11:01am
6
Hi @paul-grist .
This works only on the frontend, right?
I’m adding data (which includes ‘new choices’ as well), via the API. How do i go about adding the new choices to the Choice list in this case?
aude
January 9, 2026, 3:01pm
7
It’s possible with the API with
PATCH https://your_grist_instance/api/docs/doc_id/tables/table_id/columns
"columns": [
"id": "col_id",
"fields": {
"widgetOptions": "{\"widget\":\"TextBox\",\"choices\":[\"LIFE\",\"IZ\",\"GOOD\"],\"alignment\":\"left\",\"choiceOptions\":{}}"
