Hi!
I have a main table with PATIENTS, and I have sub-tables for each medical diagnosis, for example, ASMA.
I want to create a column in the main patients’ table with, such as isAsma, and assign 1 if the patient exists in the ASMA table, or 0 if it doesn’t.
Support asked me to use this formula:
IF(ASMA.lookupOne(Patient=$id), 1, 0)
Where Patient is the column from the Asma table, and $id is the column I’m using as a key in the main table.
But it doesn’t work, it results in 0 for all the 29k records (I have 800 records of patients with ASMA)
I hope this is understandable, feels kind of difficult to explain, any help is highly appreciated!
TIA!
Here is an example implementing this: Grist
The formula is as in the question.
Note that:
- The table Patients doesn’t have any visible column named
id
, because that’s a special column that all tables have. If you try creating one, you’ll find it actually gets assigned another identifier, although the label may still show id
- The Patient column in the ASMA table is of type Reference, referring to the Patients table. Internally each cell contains a row ID of the Patients table, but for readability it’s been set to show the Name column.
Hi @alexmojaki
Thanks! I see what was the problem in my formula; instead of using $id i was using the actual name of the referenced column $referenced_column and that didn’t work. I just changed it to $id and it worked.
I guess this is a Python thing, which I’m 0% familiar with.
Will have to keep digging to failirize with these new formulas, thanks!
Nice seeing you on the forum, David!
To clarify, ASMA.lookupOne(Patient=$id)
means "Find one record of the ASMA table where the Patient column has value $id
". More generally, it’s trying to say “Find one record of the ASMA table where the Patient column refers to this record” and maybe a clearer way to say that would be ASMA.lookupOne(Patient=rec)
which should also work. rec
is a Record object, and $id
means rec.id
, the unique ID of that record.
