How to create a column of images directly from URLs
I have a column in a table which contains URLs pointing to an image.
I would like to create a separate column which contains the actual image from the URL entry in the URL column.
I know I can download each image and add it as an attachment column, which achieves this, but this is cumbersome.
I could also view the image in a separate card using the Custom Widget Image viewer, but I’d like to see the images in a table column.
It seems this is possible in Airtable, see here via option 2 in step 2.
Is there a native feature in Grist? Markdown? Python function?
Thank you
Hi @Andrew3 !
Unfortunately, there is not a native feature in Grist that would show the actual image from a URL directly in a column. I would usually suggest the two options you already listed with the attachment column and Image Viewer custom widget.
This would be a very cool feature to add to Grist though. I’ll share this with our team as a future improvement idea!
Thank you for responding.
In excel and google sheets there is an =IMAGE function to insert an image into a cell and I was hoping Grist had something similar. It would be great to add this as a feature.
I took a quick look, but couldn’t find an enhancement request process. How does a user request a new feature?
Thanks again.
Nevermind I see there is a feature request for this feature in Github.
