I’m new to grist and this seems trivial but I can’t seem to figure it out. I have the following data
- Employee Name
- Total Hours Worked
- Hours worked in category 1
- Hours worked in category 2
- Hours worked in category 3
What I want is a pie chart with percentages of hours worked across all employees by category
What I did was put these all into columns, I then created a summary table for the totals of each category’s hours.
So now I have a summary table with the sum of total hours worked across all employees separated by category. All I want to do is take these 3 sums and stick them into a pie chart to get percentages, however it seems like pie charts don’t work this way. The data needs to be vertical not horizontal.
I tried to reference the summary data, and put it into a new table but I can’t do that either
Thanks for any help
