I need to create the final document templates, which will be auto filled from the MAIN tables.
These documents mostly would have:
border, logo, header, seal and body…
Some are double sided and others single sided
printable to printer and also to PDF
Thanks all.
You will need to create HTML code referencing each field and logo you need.
This code will be inserted in one table.
Then you will have a custom HTML widget that will refer to that table > field with your HTML code.
It’s not easy. I suggest you do that after you become quite acquainted with Grist, and then use ChatGPT to help you.
