Hi, my friends are interested in using the dashboard I created in Grist. How do I make a template that I can share with others?
Hi @school.
You can click the Share button in the top-right corner, and then click “Duplicate Document…”. Inside the menu, you can click the “As Template” checkbox to make a copy of your document without any data. Then, you can grant your friends view-only access to the template document; they’ll be able to open it and save a copy to their own site via the Share menu.
George
