When you create a card, you are able to add a column but how do you delete a column in card view?
Currently, I have to change the card view to table view in order to delete the column. Is there a better way?
Thank you
Thank you
Hi Jennifer!
Unfortunately, there is no way to delete a column from the card view. Currently, the only way is to delete it from the table view. I can see if you only have a card view that it’s a lot of steps just to delete a column. I’ll share this with our team so we can make this easier in the future.
Oh, okay good. Thank you very much
