Good afternoon colleagues.
Found Grist on Github: Grist Labs · GitHub
It has a grist-core which fills the role of a server. As I understand correctly, I still need to install additional assemblies such as grist-widget and grist-static for the system to work fully. I installed grist-core on Docker and not everything is there.
Now the question is: How can I properly install GRIST with all the utilities? and what additional utilities should I install? and how (via docker of course)
Use Grist Omnibus.
it’s also Docker and has several stuff attached.
here is my Docker Compose for Grist Omnibus.
version: '3'
services:
grist:
image: gristlabs/grist-omnibus:latest
ports:
- **8xxx**:80
environment:
- URL=http://192.168**.x.xx**:**8xxx**
- TEAM=**NAME OF TEAM**
- EMAIL=**EMAIL1**
- PASSWORD=**PASSWORD1**
- INSECURE_COOKIE=true
- GRIST_NEW_COLUMN_MENU=true
- PERMITTED_CUSTOM_WIDGETS=calendar
- GRIST_WIDGET_LIST_URL=https://github.com/gristlabs/grist-widget/releases/download/latest/manifest.json
- GRIST_EXPERIMENTAL_PLUGINS=true
#- HTTPS: "external"
- GRIST_HIDE_UI_ELEMENTS=billing,templates,multiSite
- APP_STATIC_INCLUDE_CUSTOM_CSS=true
volumes:
- /**fullpath**/Grist:/persist
- /**fullpath**/Grist/gristcss/custom.css:/grist/static/custom.css
in bold, where I replaced stuff with variable things
the main problem is that you must add email and passwords for each user.
