I’m encountering an issue with handling reference columns in my custom Grist widget. In my widget, reference column values are returned in a format like “TableName[VALUE]” (for example, “Table2[15.23]”) instead of simply returning the numeric reference ID. When I enter edit mode, I need to display a dropdown populated with data from the referenced table so that the user can select the proper option. However, if I save the record without changing anything, the widget sends back the full string (e.g., “Table2[15.23]”) rather than the expected numeric ID.
My ideal behavior is as follows:
- For a reference column, the widget should fetch data from the referenced table, build a dropdown that displays the proper values (using a display field such as “gristHelper_Display” or another designated field), and when saving, return the underlying numeric ID for the selected reference.
- Although reference columns sometimes appear as formulas in the metadata (e.g., with a formula like “$ref.Coluna3”), they should remain editable. That is, they must not be blocked like other formula fields; instead, they should allow a proper selection from the dropdown.
I’m looking for advice on how to implement this behavior:
- How can I fetch and map the referenced table’s data so that the dropdown displays the correct values?
- How can I ensure that, when saving, the widget returns the numeric reference ID rather than a formatted string like “TableName[VALUE]”?
Any guidance or examples from the Grist Forum or documentation would be greatly appreciated.
