How to use Notepad widget?
I created a custom widget “Notepad” in a document. I set “Select Data” from a table and then “SELECT BY” the same table.
When I select different records in the table, the content inside Notepad doesn’t change.
So, the Notepad is associated with the whole table, not individual records?
Hi @GG1.
In the right panel under the “Custom” tab and “Widget” sub-tab, there’s a section at the bottom that lets you pick a text column to use. Is it filled in?
George
No, it’s not. I wasn’t prompted.
So, I fill it in now. But the entire notepad I’ve worked on today is gone. :cold_sweat:
