Https for authentication?
Perhaps this is just misleading documentation, but is the API / authentication supported over https?
Authentication
API Key
Access to the Grist API is controlled by an Authorization header, which should contain the word ‘Bearer’, followed by a space, followed by your API key.
Security Scheme Type: HTTP <----- ?
HTTP Authorization Scheme: bearer
Bearer format: Authorization: Bearer XXXXXXXXXXX
I use API over HTTPS without any problems.
