Integration with Pabbly, Integrately, etc
Hi there,
I am successfully connected to Pabbly and Integrately, but something is wrong, because the new records are not successfully being added in Mailchimp when Grist record is created. Basically, created a Readiness column (titled Ready) that is to trigger to the integration. It has this boolean formula: $email_1 and $first_name and $last_name. The test data is found; however, when a new recorded is added to Grist, the new subscriber is not added to Mailchimp.
Any suggestions are welcome. Thank you
Check in Pabbly the workflow history if there is any history? If not, trigger in Getgrist is not working. Else step 2 in Pabbly is not working.
