Great work on Grist !
Do you have any plans on adding features available in Rows.com ? Like buttons, forms & integrations with many 3rd parties ?
Thanks !
Thanks !
Hi Michael, welcome to the forum!
Yes, we do plan on implementing buttons, forms and native integrations. Our roadmap is public on Github: Roadmap for Grist · GitHub
There is a custom widget for action button available from the custom widget menu. Here’s an example Action button to duplicate a record If there’s something specific you’d like to do, we’re happy to help.
Re: forms, you can connect a form to Grist by using any of the integrators we support: Integrator Services - Grist Help Center
By the way, depending on your use case, it may be sufficient to use access rules to simulate a form-like experience in Grist. Here’s a couple examples: Simple Poll and Public Giveaway.
Yesterday’s webinar walked through access rules and the Public Giveaway example in particular: Build with Grist Webinar - Access Rules - Mar 16, 2022 - YouTube
Where can I find more info about action buttons? It’s helpful to have the example doc, but some written info on the syntax of the set-up, etc, would be great to fill in a few blanks!
I’m using Rows and learned 2 days ago about Grist. It looks awesome in general, but lacks some important features that Rows have, such as:
SCHEDULE, REPEAT, REFRESH (see: `cron` / `schedule` / `repeat` / `refresh` and `CRON` / `SCHEDULE` / `REPEAT` / `REFRESH` · Issue #1401 · gristlabs/grist-core · GitHub)GET, POST, PUT, PATCH (it seems Grist has a REQUEST function that’s only available in self-hosting, but I don’t want to self-host)
