Is it possible to have a calendar widget cover two tables?
Hello everyone!
I’m wondering if it’s possible for a calendar widget to display events from two (or more) different tables at the same time.
See the following document for an example of what I’m trying to achieve. I want the calendar to display both 4 events:
Events union - Grist
I’ve tried to follow the method in the following post to get a summary table that looks exactly the way I want. But unfortunately, the calendar widget cannot rely on a summary table:
Combine two tables into a single summary table? - #3 by Dmitry_Sagalovskiy
Is there a way to achieve this ?
Thanks!
Yann
I was wondering the same thing. Combining in a table is excelent, combining in the calendar would be very much helpful as well.
Just adding a +1 for this feature request :slight_smile:
