Is it possible to move a widget to a page on it's own?
I added a widget to a page, and spent quite a bit of time building it. Now I realize I want this widget to have a page on its own and not be shared with anything. I can’t seem to find a way to somehow “copy” the widget to a new empty page. Any ideas?
Hi gristexplorer!
You should be able to duplicate the page on which your specific widget resides. There is an option on the Grist left window to rename, remove of duplicate each page.
This way, you could clean up the duplicated page to only leave the widget you want, and if needed, remove the widget from the original page.
Michel
Master. Wise one. Thank you.
It’s a solution.
UNLESS you want to widgets created in different pages to be in the same page.
Usually there are enough few settings that it’s not that complicated.
But it is complicated for Custom Widget Builder, for Advanced Charts (a chart widget may have enough customization that you spend over 15 minutes on it)
