Jinja templating in custom renderHtml
Dears,
Finally I found that renderHtml custom widget does the job for small custom prints, easy records.
I was yet wondering if it could be possible to include some jinja templating system, it would for iteration, conditions …
Thanks !
It is a good idea. If you know html/css/js, making a new type of custom widget is pretty easy, and there are examples here:
Custom widgets themselves can use templates by including a templating framework. We’ve written some with Vue.js which has constructs you would recognize as jinja-like, e.g. the invoice widget has lines like:
Thanks for your advices.
I have practiced a little vuejs for internal stuff.
I am not a developper and I’m not as comfortable with js as I am with python (flask dev for small needs)
I found really powerfull to have python in cell (even fonction are supported) so I’m writting the html result in python and was thinking jinja could help clarifying the result.
=> Does this mean I can directly write with vuejs directive (framework already included) or do I need to incorporate it ?
=> I also need to serve my customwidget from a githubpage → to be initiated
