JOIN/UNION and Column Auto numbering ( not UUID)
GRIST is a wonderful product, that could be made even more wonderful if you could please add a couple of power features.
  1. The ability to create a table based on a query of multiple other tables ( like a VIEW)
  2. The ability to join/union tables based on a common criteria
  3. A simple function that enables auto numbering ( or incrementation of cells) in a column based on the last number + some formula and also auto sequences.
Many thanks
Keep up the good work
For the 3, you should be able to refer to the precedent record within a trigger formula. For example, this trigger formula gives letters in alphabetical order (replace “A” by the name of your column):
id = table.all.id[-2]
chr(ord(table.lookupOne(id=id).A) + 1)
