Locale settings for calendar widget
Using the calendar widget is annoying if you want use your locale settings. Here in europe our days have 24 hours, not 12 on the first and 12 on the second half of the day, so we would prefer to use a 24h time format even in calendars - and our weeks start on monday not on the weekend. Setting the locales in Grist does not change anything in the calendar widget. Why?
Another missed feature is a way to scale the calendar. In a event calendar with events with a duration of 10 or 20 minutes it is not possible to read the event title. It would be useful if we coul limit the time of the daily calendar from 9 to 5 for example and, second, to scale into the hours for more detailed views.
temp
Hi there,
Thanks for this feedback. I’ll share it with our team and see what we can do to improve the calendar widget.
Any news about this? I can’t find an issue on Github about this.
Thanks!
Hey @Marc_SCHNEIDER ,
Thanks for checking in on this! We’re a small team and are currently focused on other priorities, but we know this is an area that could be improved and it’s something we’d love to revisit in the future. We prioritize updates based on user feedback, so as more people ask for this, it definitely helps move it up the list. I’ll add you as a +1 vote👍
Users can submit product improvement ideas through Github but also through our Community Forum, Discord, or by emailing support. I keep a record of all of them!
For those finding this thread, if you would also be interested in this update, add a comment and I’ll log your vote as well! :grin:
We will definitely be interested in this yes :smiley:
Thank you!
I’m interested in more options in the calendar view yes.
Yet another european here!
Having the Calendar-widget as well as the Date/DateTime selection popups either respect the Document Locale OR be able to set a custom format (both per document and as a default for new documents) would be a great feature to have.
Consider this my +1.
In fact, having the datepicker start on Sun instead of Mon causes errors in my company.
We are a travel agency. One of our trips start on Tuesday… then agents just “visually select the second column” like this:
In ALL our other tools the “second column” is the day the trip departs. Then they inform 18-aug in grist when they should have informed 19-aug.
This causes great data-loss and potentially money-loss.
We should be able to set the datepicker to “What day does it start”.
I don’t need to deal with complex locales and so… it can be just a config param: “What day does the week start on” and pass that param to the “widget”. If not configured, use the default.
Can this be easily implemented?
I’d be happy to contribute if anyone tells me how.
I vote too to have a calendar more usable:
  • it should be able to start weeks on monday
  • it should be able to display hours in 24 per day format
  • it should be able to hide week-ends to not waste screen space (2 columns always empty on my work calendar!)
  • it should be able to display at “today” directly on page opening, and not at the latest date!
    As of today it is a pain, we avoid using it.
I’d love to be able to type 4/8/26 into a date field and, because I set the document’s locale to UK, have it recognise the date as 4th August 2026 rather than 8th April 2026 irrespective of the display format that has been set for the field.
So, +1 from me
I’d like to vote for better scaling as well. There is potential to use the calendar widget for some of our scheduling needs, such as event planning. Many parts of it are just about 15 minutes long and basically not visible in the calendar.
