Lookup when field is not None
How to have LookupOne but with a field not a certain value (None in my case)
In my example, I have Items, Item Movements and Event tables.
In Items, I have a column Last Movement that is Item Movement filtered for this Item, but I want to filter out movements where Event is not defined.
I have tried with: Event=CONTAINS(Events.all) but as you can see I have a #TypeError
How can I figure it out ?
I’ve masked out some sensitive data
You could have a has_event column (of type Toggle, that you may hide if you want) in Item Movement, that you would define as follows: not not $Event.
Then your formula becomes Item_Movements.lookupOne(Item=$id, has_event=True, order_by=”-Date”).
Ok, thanks, that works well
