Map Widget Enhancements
Hi All,
And thank you for Grist, a tool we have been using here for several years.
I recently discovered the Map Widget and would like to suggest several enhancements or ask if there is a way we can develop them by ourselves (then share with the community):
  • change the color of the pins, depending on a criteria in the table
  • display names attached to each pin
  • change the underlying map background
  • add layers to the background map (e.g., country borders)
  • display zones instead of only being able to display geographic points. That would entail being able to add GeoJSON records to the table
That is all (for now).
Stephen
