I’m creating a markdown view and I’d like display a lookuprecords formula.
For the moment I’ve this formula Ateliers = Atelier.lookupRecords(Projet=$id).Nom_atelier and return this
How can I display it like this :
- Aôn - chaumié #1
- Aôn - chaumié #2
- Concert Aôn
Thanks for the help !
Hey Pierre. The reason that it’s formatted like that, is because lookupRecords(...).Nom_atelier is returning a list of names. You’ll want to transform that list into a bullet point list in markdown:
* Item A
* Item B
* Item C
You can use a snippet of Python code like this to do it:
entries = Table1.lookupRecords().A
bullet_points = [f"* {entry}" for entry in entries]
"\n".join(bullet_points)
This:
- Does a lookup to produce the list
- Creates a new list, where each item in the list is a line of text prefixed with
- Joins those list entries together with newline character, to create one big block of text containing your final markdown.
Hope that helps!
Thank you.
I try it but I’ve an error a Syntax error…
I try this :
bullet_points = [f"* {Atelier}" for Atelier in Ateliers]
And in my template I call {Ateliers}
Copying and pasting that, it seems to work fine at my end. The only thing I had to do is delete the indentation (the spaces and tabs) at the start of the lines. Could you remove those in your formula?
I’ve delete spaces and tabs but I still have a SyntaxError…
All my code :
# Finds all data associated with this record
class Find_Data(dict):
def __missing__(self, key):
return getattr(rec, key)
# Finds the "Proposal" template in the Templates table
template = Fiche_projet.lookupOne(Nom="Projet").Modele
# Formats the template with fields from this table as well as fields from the referenced table
template.format_map(Find_Data(
Partenaire = $Partenaire.Structure,
Partenaire_adresse = $Partenaire.Adresse,
Partenaire_tel = $Partenaire.Telephone,
Partenaire_rep = $Partenaire.Directeur.Name,
Fonction = $Partenaire.Directeur.Fonction,
date = TODAY().strftime("%d/%m/%Y"),
Looks like you’ve put three lines of code into your parameter list for Find_data:
You probably want something more like this:
nom_ateliers = Atelier.lookupRecords(Projet=$id).Nom_atelier
nom_ateliers_bullet_points = [f"* {atelier}" for atelier in nom_ateliers]
nom_ateliers_bullet_points_markdown = "\n".join(nom_ateliers_bullet_points)
Ateliers = nom_ateliers_bullet_points_markdown
There might still be issues there as I can’t run the code, but it’s a bit closer to working!
Yes It works !
Thank you for the help.
I’m very enjoy about grist for custom tool for management project.
No problem at all! Good luck and have fun
