Mp3 attachment rewind
Hello!
Just added an mp3 to the table and it plays well but I’m not able to rewind it to custom position. Slider doesn’t work.
Thank you for flagging this, Konstantin! :raised_hands: Does the issue persist after fully loading the clip?
I’ve experienced something similar with the video player and often it clears after the video fully loads. It’s definitely a feature we can improve and I’ve made a note about it internally.
I don’t think so, because it was a pretty small mp3 file of 1+mb.
I’m not able to go back too.
Just tested until the whole mp3 was played (to be sure it was loaded) and tried to change current position without luck.
Thanks for digging in a little more. I made a note to implement a fix!
The player is actually a native one to the browser, using an <audio> tag, so this behavior depends a lot on the browser and operating system. Which browser/OS are you on, where you are seeing this?
Hello Dmitry!
I have never had a problem with the native audio player in the browser.
Win11 / Edge + just tested in Chrome = same problem.
But I found some information that could help.
It does not work the first time it loads, but if I close the player and open the same file again by pressing play, it loads and works fine.
Here is the video.
433Do9Jnc1
I found a post that sounds like a plausible explanation of what the problem may be:
google chrome - HTML5 video will not loop - Stack Overflow. If correct, we could probably fix that.
