If you change your code from using None to using “” (just two quotation marks in a row, which means the cell is blank), then it should work I tried it out in your example and it seemed to work, anyway!
I’m not an expert, but I suspect that this is because the cell isn’t None-type, it’s just empty.
Sometimes in Python it’s helpful to distinguish an empty string from no value at all. E.g. in Grist, a Numeric or Date column may have an empty value, and it makes sense for it to be None rather than the empty string, since it’s not a string of text at all.
A string has various operations (e.g. it’s valid to add it to another string, or get its length, or turn to uppercase). When those operations don’t make sense, a None value helps avoid confusion.
But in other cases, like yours, it can add confusion
Some rule of thumb I’d recommend:
When comparing values, use
if $Value rather than if $Value != None or if $Value != "".
if not $Value rather than if $Value == None or if $Value == "".
Simply using $Value is treated as false when it’s None, empty, or 0, and as true otherwise. Same in other conditions, e.g. IF(not $Name, ...).
Reserve None for exceptional values. When operating with particular types, use that type. E.g. when adding strings, use empty strings (""); for numbers, use zeroes.
By the way, as an aside, Python string formatting is great for cases like yours. E.g. you can replace
CONCAT(
LEFT($Name),
with the shorter
" {}.".format(LEFT($Name))
(the empty curly braces get replaced with the arguments).
Also, the “Conditional Expressions” tip from this newsletter is often helpful. Some examples from there:
$Birthday.year if $Birthday else None
$Total / $Count if $Count else 0
" {}.".format($Name[0]) if $Name else "" # Your example
