Hi folks! I have this situation:
There is any way to have no duplicates at “Reniao_projeto” ?
Thanks in advance!
Eduardo
Thanks in advance!
Eduardo
Hi @Eduardo_Dalcin, you can achieve this quite easily with a formula:
records = []
seen_projects = []
for r in Reuniao.lookupRecords(participantes=CONTAINS($id)):
if not r.projecto in seen_projects:
records.append(r)
return records
Note that this won’t remove any duplicates in the ‘Reuniao’ table. It just won’t show them in your column. Hope this helps!
Or you may use Set:
tuple(Set(Reuniao.lookupRecords(participantes=CONTAINS($id)).projeto))
