The main objective with the Kanban I am creating is that it will be VERY GENERIC… being able to use anywhere.
So in the first screen you only see it after first placing the code in the Custom Widget Builder.
when clicking CONFIG you have access to configurations, done in two tabs. This first tab you choose what column you will use to map the Kanban columns
it’s important to notice the Kanban gets the column colors FROM the Options Column you mapped
now let’s customize our cards
No Card (In the Card) means that column will appear in the card.
Usar Formatação means the Widget will access the formatting options of the column (header formatting, cell formatting, options formatting and even conditional formatting)
Card Pos# regulates the order of the fields that will appear in the card… in the card.
Mostrar Label Card means Show Label Card. Disabling it means that instead of Country: Brazil, it will show only “Brazil”
Now for something cool… the configurations are done BY column. But you can replicate the configurations to the next column or to all other columns.
so, continuing… as you can see here, I configured only the first column to use the fields in the card.
but clicking on “Replicar p/ Todas” (Replicate to All), now all columns show the same fields in the cards
now… when clicking on a card, you go to the card editing screen
Oops, there are fields I don´t want shown there, like gristHelper_Display
so… I select first Column of the Kanban (in this case could be any column… order the fields by name and at “Visible Drawer” column I disable the 3. THey are not visible anymore. But first, I will replicate to all Kanban columns.
Now… when the process starts, the first user must insert name, company and group of the employee. But at second column, the task is to add other details. Nobody can change those fields anymore.
SOOOO… they will be visible but blocked to edit.
and… see, Nome Funcionário is blocked to edition
I am still working on this. Several features will be added:
ToDo List
1 - set maximum cards viewed per column
2 - set maximum number of cards per column (indicating an employee or department can´t do more than X of that tasks at the same time)
3 - set responsible PER column. Only someone belonging to group or user itself may move FROM that column to others
4 - option to not allow moving a card more than one column
5 - rules to create new card in another Kanban when moving to a certain column, and make that a child Kanban (a sub process)
