Vince_M
December 12, 2025, 9:47am
1
I have challenges integrating OIDC with Microsoft. Here is the error I get
Below are my configs:
#Microsoft OIDC
GRIST_OIDC_SP_HOST: https://grist.xxxxxx.yy
GRIST_OIDC_IDP_ISSUER: https://login.microsoftonline.com/xxxxxxxxxx/v2.0/.well-known/openid-configuration
GRIST_OIDC_IDP_SCOPES: "openid profile email User.Read"
GRIST_OIDC_IDP_CLIENT_ID: xxxxxxxxx
GRIST_OIDC_IDP_CLIENT_SECRET: xxxxxxxxxxx
GRIST_OIDC_SP_PROFILE_NAME_ATTR: name
GRIST_OIDC_SP_PROFILE_EMAIL_ATTR: email,preferred_username
Any assistance is much appreciated.
Hi @Vince_M , that error message suggests that the identity provider has an account for your email address, but has it marked as unverified (for example, that a link or code in a verification email sent to that address wasn’t acted on). This could be real or a misconfiguration of some kind. In OIDC - Grist Help Center I see a GRIST_OIDC_SP_IGNORE_EMAIL_VERIFIED setting if you are confident this status should be ignored in your case.
Vince_M
December 12, 2025, 5:55pm
3
Hi @paul-grist ,
If I add that env variable suggested, login succeeds but email field is undefined
I have decoded the jwt id token (using similar flow in a different app) and it shows the following, real values redacted.
Since email, preferred_username, upn are all available in the token, I fail to understand where the real issue will be.
"typ": "JWT",
"alg": "RS256",
"kid": "REDACTED_KEY_ID"
"aud": "REDACTED_CLIENT_ID",
"iss": "https://login.microsoftonline.com/REDACTED_TENANT_ID/v2.0",
"iat": 1765558591,
"nbf": 1765558591,
"exp": 1765562491,
"aio": "REDACTED_AIO",
"email": "REDACTED_EMAIL",//email is available
"name": "REDACTED_NAME", // name is available
"oid": "REDACTED_OBJECT_ID",
"preferred_username": "REDACTED_EMAIL", // is available
"rh": "REDACTED_RH",
"sid": "REDACTED_SESSION_ID",
"sub": "REDACTED_SUBJECT_ID",
"tid": "REDACTED_TENANT_ID",
"upn": "REDACTED_EMAIL", // upn is available
"uti": "REDACTED_UTI",
"ver": "2.0"
.[Signature]
Below is the optional claims settings in Azure
Vince_M
December 12, 2025, 6:31pm
4
Microsoft → Does NOT Send email_verified
Instead, claim available:
"verified_primary_email": [
"xxxxxx@xxxxx.yy"
Hope this exception can be updated, and hopefully Do NOT require the email_verified claim
@Vince_M you could report your findings as an issue on GitHub - gristlabs/grist-core: Grist is the evolution of spreadsheets. where the maintainer of the OIDC connection (fflorent on github) is more likely to see.
