I have a table of Suppliers
Each supplier has a few materials it sells.
In the suppliers table, its the column “material types”, which is a REFERENCE LIST type. (actually it’s a two way reference… there is a table called ProductsBySupplier, one row for each material that supplier sells… being a reference to materials table. Since it’s a two ways reference, it creates a reference list on suppliers table)
Ok… I also have a table called Purchases, and each purchase may have several items: Purchase_Items.
I select the supplier at the Purchase table. And at Purchase Items, I need to select a raw material type.
And I want ONLY the materials THAT supplier sells to appear, instead of the whole list of materials.
