Possible to Automatically Insert Rows into Another Table without using a widget?
Based on all of my research and testing so far, it does not seem possible to automatically add/update/delete records based on some action/trigger, such as when a new record is added to a table.
I’m hoping this is in-fact possible somehow. If not, I would like to nominate this as a feature request which would unlock a lot of great functionality!
I have created shared a document to explain what I’m trying to achieve:
https://docs.getgrist.com/wdC9yriF7nkA/Attribute-Auto-Add-Testing-SHARED/m/fork
Summary of the Tables:
  • Cars - A list of cars and a summary of the required attributes that have been defined for each car
  • Car Attributes - A list of zero or more attributes that have been associated with a specific car from the Cars table.
  • Master Attributes - A list of possible attributes that can be assigned to a car, which get stored in the Car Attributes table. Each attribute can be marked as Is Required.
GOAL:
  • When a new car record is added to the Cars table, I want to automatically (without any user intervention) add records to the Car Attributes table that are associated with the car.
  • Attributes should only be added if Is Required is True in the Master Attributes table.
  • The default value of the attributes added can be a blank string (later, I could define a default value to use in the Master Attributes table for each attribute).
Is this possible to achieve in Grist as of today without using a widget (e.g., Action Button, Autoaction, PugPy)?
If not, my feature request would be something like:
  • Allow code in Grist (e.g., in Formula and Trigger columns) to modify data in the document (add, update, delete).
  • For example:
    • TableName.addRecord(Record)
    • TableName.updateRecord(id, Record)
    • TableName.removeRecord(id, Record)
Thanks!
I’ve been looking all over the place for this as well: basically any ‘native capability’ for automations (Read: Airtable style automations).
External integrations (using Webhooks/Grist API) are effective & efficient, only so much.
Internal/Native automations, like the ones mentioned in the OP, are pretty ‘crucial’ these days.
Would widget button be a possible work around?
