Is there a programmatic way via formulas to get the label of a given column?
For example, suppose I have a field with a label of “Is Valid”. The internal name of this would end up being Is_Valid. In code, I would like to have a property on the column such as TableName.Is_Valid.label.
It would be equivalent in what the docs/{docId}/tables/{tableId}/columns API endpoint returns for the column in the fields.label property:
"columns": [
"id": "Is_Valid_",
"fields": {
"colRef": 686,
"parentId": 78,
"parentPos": 657,
"type": "Bool",
"widgetOptions": "",
"isFormula": false,
"formula": "",
"label": "Is Valid?", <-------
"description": "",
In the meantime, I thought about just taking the internal column name and replacing underscores (_) with spaces… but spaces are not the only things that get replaced with underscores when the internal column name is created. Like in the API response snippet above, a label of “Is Valid?” would become Is_Valid_, so converting the other way would not bring my question mark back.
If this is not possible, consider this a feature request. ![]()
Thank you.
