Print View Suggestions - some tweaks
As you can see in the image below - Any and all print shows Doc name - Grist in header and the footer needs to be eliminated with the links or edited to taste.
Hi @Vignesh, can you check for an option in the print dialog to turn off headers and footers? In Chrome and Firefox, there is a checkbox under [more settings] → [(print) headers and footers] that you can turn off. Does that work for you?
