Is there a way to get a field back that I have deleted. Or a way to permanently delete is so I can re-use the description?
You can see that I must have used the field description of “t15s15” before as Grist had given it a Column ID of $t15s15_2.
I no longer have the original “t15s15” field. But when I am creating formulas, it’s annoying since I don’t remember which fields I need to add _2.
The original field is no longer in the table. Is there somewhere I can go and permanently remove the field so I can use the name again? I looked in Code view and didn’t see anything there.
Help
