A main reason I’m interested in Grist is due to spreadsheet software having a ~1 million row limit.
Grist compares itself to spreadsheet software but says nothing about the ~1 million row spreadsheet limit. The only limits you mention are for your SAAS offerings. Limits - Grist Help Center
Some background and general feedback:
I started off with Libreoffice calc, but I find that Excel has more “quality of life” features, such as easy navigation by double-clicking the edges of cells, etc. And it handles memory/large files much better.
Excel is highly problematic for .csv files since it automatically converts data, and the “import text” options are difficult and not always 100% functional.
Both of these have the problem of being limited to ~1 million rows.
I tested others like Modern CSV and Rons Data Edit, and they weren’t better.
I saw OpenRefine being recommended but it seems very limited and doesn’t have all the features I need.
The main features I need are:
- Remove whitespace
- Remove duplicates
- Cut/copy/move large amounts of data from one sheet to another, or within a sheet/database. Eg: insert 100,000 rows before another million rows.
For everything else, I can just use Excel. But being able to use autofill in the database program would be very nice.
I watched your “find dupes” tutorial, and it looks like it would work for my needs, but ideally it could remove duplicates across multiple pages.
For the ~1 million row limit it was recommended that I switch to a database. Libreoffice has a database but from what I recall, it had the same memory issues as Calc, and kept crashing when importing/using large files/databases.
I need to be able to look someone up in the database via their email address, then copy and paste their row into a spreadsheet. So Grist advertising itself as a “database with spreadsheet UI” sounded very promising. And it appears that Grist can do this copy-paste task.
I was a little disappointed that Grist doesn’t have the vast majority of basic functions that spreadsheets have, despite advertising itself as “equal to + better than” Google sheets, Excel, etc.
