Hello Grist Team!
In doc i find ROW()
As far as I understand, the formula should return the line number for widget, for example:
ROW($id)
This is right?
Adding this formula should remove many questions about auto-numbering rows.
Hello Grist Team!
In doc i find ROW()
ROW($id)
This is right?
Sure, when it’s implemented. Meanwhile, the best ways I know are:
manualSort
in account:table.lookupRecords(sort_by="manualSort").id.index($id)
table.all.id.index($id)
Thank you @jperon for you help!
Just now try
Items.lookupRecords(Invoice=$Invoice).id.index($id)+1
Works for my Items in Invoice!
Depending on your use case, adding a sort_by
clause could be a good idea (for example to sort by date).
