Hi @ferran, sorry you’re having trouble. That’s odd, so in $PWD/persist you see the files grist-sessions.db and home.sqlite3, but you do not see a docs subdirectory? If I run that docker command, afterwards I see three items in $PWD/persist:
$ ls persist/
docs grist-sessions.db home.sqlite3
Do you see some lines like this as Grist starts up? Especially the docsRoot line:
With a -d docker will run Grist in the background, you’d need to use docker logs to read logs in that case.
The grist directory at the same level as docs in your listing confuses me, and the ~/grist/docs. I’m not sure how to relate that to the $PWD/persist directory.
If you’ve been using -d, maybe make sure there aren’t any extra unexpected containers running with docker ps?
Anyway, it looks like you are seeing at least one .grist file on your host, outside the Grist container, so there is hope
