Sandbox/pyodide error
Hello, an error has occurred since the last update, the document is not loading and errors are being issued:
Server log
  __error_address: 9652864
  type: 'ModuleNotFoundError',
    at main (/grist/sandbox/pyodide/pipe.js:141:16) {
    at GristPipe.runCode (/grist/sandbox/pyodide/pipe.js:104:24)
    at Object.runPython (/grist/sandbox/pyodide/_build/worker/node_modules/pyodide/pyodide.asm.js:9:123292)
    at Object.apply (/grist/sandbox/pyodide/_build/worker/node_modules/pyodide/pyodide.asm.js:9:88624)
    at Function.apply (/grist/sandbox/pyodide/_build/worker/node_modules/pyodide/pyodide.asm.js:9:89846)
    at Module.callPyObject (/grist/sandbox/pyodide/_build/worker/node_modules/pyodide/pyodide.asm.js:9:75942)
    at Module.callPyObjectKwargs (/grist/sandbox/pyodide/_build/worker/node_modules/pyodide/pyodide.asm.js:9:75733)
    at Module._pythonexc2js (/grist/sandbox/pyodide/_build/worker/node_modules/pyodide/pyodide.asm.js:9:656029)
    at wasm://wasm/02239a6e:wasm-function[292]:0x152e6c
    at wasm://wasm/02239a6e:wasm-function[291]:0x152d67
    at new_error (/grist/sandbox/pyodide/_build/worker/node_modules/pyodide/pyodide.asm.js:9:14992)
See https://pyodide.org/en/stable/usage/loading-packages.html for more details.
  await pyodide.loadPackage("six") in JavaScript
  await micropip.install(\"six\") in Python, or
You can install it by calling:
ModuleNotFoundError: The module 'six' is included in the Pyodide distribution, but it is not installed.
    import six
  File \"/grist/usertypes.py\	 line 22	 in <module>
  File \"/grist/grist.py\	 line 8	 in <module>
 in <module>
  File \"/lib/python311.zip/_pyodide/_base.py\	 line 310	 in run
  File \"/lib/python311.zip/_pyodide/_base.py\	 line 468	 in eval_code
    at fe.onmessage (https://grist.setup/v/unknown/main.bundle.js:2:34996)
    at fe._processReceivedMessage (https://grist.setup/v/unknown/main.bundle.js:2:36374)
    at fe.trigger (https://grist.setup/v/unknown/main.bundle.js:2:967060)
    at d (https://grist.setup/v/unknown/main.bundle.js:2:965120)
    at g (https://grist.setup/v/unknown/main.bundle.js:2:967167)
    at b (https://grist.setup/v/unknown/main.bundle.js:2:967375)
    at ye._onServerMessage (https://grist.setup/v/unknown/main.bundle.js:2:42684)
Am I the only one so lucky?
I just updated the container to the latest version, the problem does not repeat! Thanks!
