Self-hosting limitations
Hi there,
Can you help me understand the limitations of self-hosting?
Grist looks like a great tool and I want to implement it at my org but we don’t have the budget for paid subscriptions- however we do have 24hr servers strong enough to support self-hosting Grist and a PostgreSQL backend if needed.
These are my requirements:
  • Worksheet 1 supports up to 15k rows and up to 100 columns, 30 columns have formulas
  • Worksheet 2 supports up to 15k rows and up to 45 columns, 38 columns have formulas
  • Can support up to 15 concurrent users in the worksheet
  • Formulas reference other worksheets
  • Supports multiple worksheets and allows csv import to add rows
  • Cell with formulas can be overwritten
  • Live/real-time updates
  • Users can add, update, delete, read, import csv and export csv data
I am most concerned about the top 3 requirements, while the remaining requirements drew me to finding Grist. I would love to use this tool :slight_smile:
Isabella
I would expect all of that to work fine. There are some numbers on the basic hardware requirements here:
Thank you Paul! That’s really helpful, I was able to confirm that our hardware can support self-hosting :slight_smile:
Do you know if the Grist Community edition would support these requirements? I am most concerned about row limit and having many concurrent users
Isabella
The community edition doesn’t have limits on rows or concurrent users, beyond what your hardware can do.
Amazing, thank you so much for taking time out of your day to answer these questions :slight_smile:
