Bonjour
I would like to put checkboxes in the custom widget
to be able to modify the current row in the list , is it possible ?
Or I should call the REST API in the html with the ID ?
Hi Sao,
To update a row from a custom widget you can use the following snippet:
// Get current table API object.
const table = grist.getTable();
// Update column is_cover in row that has id = 2
table.update({ id: 2, fields : { is_cover : false }});
Those two methods are documented here:
getTable
update record
Let me know if this helps in your use case.
thank you very much
, Iโll try it this night.
And can use the โfilterโ and "sort " method on a Table ?
thanks
