Showing a description for multiple column mapping
I’m making a custom widget, and have them declared like this:
		title: "Description",
		description: "Field with the main information",
		optional: false,
		type: "Text",
		allowMultiple: false
		title: "Additional fields",
		description: "Add extra fields here, for instance: […]",
		optional: true,
		type: "Text",
		allowMultiple: true
It displays this in the side panel:
This looks good for “Description”, as the description is shown underneath.
But for “Additional fields”, no description is shown. However, this might be an important description as it tells the user what kind of columns to map there.
How does one display this description? Is there a different description property for multiple columns?
Thank you!
