SQL API End Point
Hello, I am trying to use the Grist API endpoint for SQL queries. I tried to run this command on the CMD:
It seems to not be able to connect for some reason. How would I mitigate this problem.
Thank You,
Tazwar Belal
I was able to run a query through python and it worked, just needed the CLI version of it.
Tazwar Belal
It looks like you’re missing a closing " at the end of your Authorization header and before the URL starts. I’m not sure if that’s the only issue, but that’s one I noticed
You must also quote the whole url.
Thats a common error; you see that curl tries to connect to the server “Percent” “FROM” etc…
