SQL api endpoint "ORDER BY" + "WHERE" + "LIMIT" error in syntax
I try to port some of my code to the new sql endpoint, but i encounter an issue.
It seems that “ORDER BY” + “WHERE” + “LIMIT” clauses in combination are not allowed/supported.
At least i get an error message. Every one of those features work in isolation however:
# Works:
SELECT id, date FROM Checkresults LIMIT 10
# Works:
SELECT id, date FROM Checkresults ORDER BY date
# Works:
SELECT id, date FROM Checkresults WHERE date <= 1696634277
# Works:
SELECT id, date FROM Checkresults WHERE date <= 1696634277 LIMIT 10
# Does NOT work:
SELECT id, date FROM Checkresults ORDER BY date WHERE date <= 1696634277 LIMIT 10
# The Error: {"error":"SQLITE_ERROR: near \"WHERE\": syntax error"}
# Does NOT work:
SELECT id, date FROM Checkresults WHERE date <= 1696634277 LIMIT 10 ORDER BY date
# The Error: {"error":"SQLITE_ERROR: near \"ORDER\": syntax error"}
# While this works again :):
SELECT id, date FROM Checkresults  WHERE date <= 1696634277  ORDER BY date
Any Tip? It seems like a bug, though.
Should i open a github issue?
Try putting WHERE before ORDER BY?
What do you mean?
this i tried:
Right, and then LIMIT should stay at the end.
Then i get this:
SELECT id, date FROM Checkresults WHERE date <= 1696634277 LIMIT 10  ORDER BY date LIMIT 10
# {"error":"SQLITE_ERROR: near \"ORDER\": syntax error"}
SELECT id, date FROM Checkresults WHERE date <= 1696634277 ORDER BY date LIMIT 10
scratch head yes this works. Thank you!
You can see the full available syntax here:
https://www.sqlite.org/lang_select.html
