This may have been asked before but I can’t find such a topic.
I have a table with columns Year (integer), month (integer), value (number). The data has 48 rows (i.e. four years worth of data) and will add 1 row per month (obviously)
I’d like fourth column with the previous 12 months total to show trends in the data - I’ve tried and failed to find a ‘pythonic’ solution to this that can work in a generic way such that I can change the 12 moths rolling total to, say, quarterly or half-yearly.
I’m sure some of you will have solved this problem, or something similar so any pointers would be most welcome.
M
Does this example work for you? It adds one column to aggregate the last N rows and a second column to add them up.
https://docs.getgrist.com/xoWve49bdNEY/Recurrance-Ordered-by-data/p/2
@JordiGH
Thanks - looks like that method will get me the solution I need. Thanks so much for chiming in
This is the formula I used - not the cleanest Python code, but it works!
ThisMonth=$Month
ThisYear=$Year
total = 0
for _ in range(12):
row=Periods.lookupOne(Year=ThisYear,Month=ThisMonth)
total += row.Distance
ThisMonth=ThisMonth-1
if ThisMonth==0:
ThisMonth=12
ThisYear=ThisYear-1
return total
Check out also the recently added PREVIOUS function.
E.g. it allows you to write a formula like this, for a column Rolling_Sum of type Numeric, which would give a rolling sum within a month:
prev = PREVIOUS(rec, group_by=("Year", "Month"), order_by="Date")
return prev.Rolling_Sum + $Distance
(Just be sure to set the column type to Numeric, so that it defaults to 0 for an empty record rather than None. Alternatively, replace prev.Rolling_Sum with (prev.Rolling_Sum or 0).)
For a rolling sum, in a table of months, you could use the related RANK function with a lookup to find a record that’s N steps back in order. Here’s an example to get a rolling 6-month sum:
Here, the Rank column is:
RANK(rec, order_by="Month")
And Rolling 6-months column:
prev = PREVIOUS(rec, order_by="Month")
old_rank = $Rank - 6
if old_rank > 0:
old_amount = Activity_summary_Month.lookupOne(Rank=old_rank).Amount
else:
old_amount = 0
prev.Rolling_6_months + $Amount - old_amount
For “average”, I would add a separate column to divide the sum by the number of months (6 in this example).
@dmitry-grist - I saw those functions but couldn’t get my head around how I’d use them so went with the vanilla python. Your solutions look really elegant and I’ll use them going forward.
