This is from an adaptation of the Lightweight CRM template.
I want to total each column and then starting from Answered?, divide each column total by the one before to get a % success rate for each step where YES is (obvs) a success.
I explain the same in this 1 min video: Recording #34
If someone can point me in the right direction, it would be much appreciated!
As @jperon suggested, Summary Tables are a good solution. The only hard part would be to convert Choice columns to numbers, to treat YES as 1 and NO as 0, as by default, they are text, and Grist won’t be able to count them. As an alternative, you can use a Toggle column as in this example.
