Teams as subdomains on self hosted instead of subfolders
When using Grist hosting, teams are added as subdomains, which works very nicely, for example
myteam.getgrist.com
When self hosting, teams are added as a folder after the domain, for example mydomain.com/o/myteam.
Is there any way this can be setup as myteam.mydomain.com instead? Are there any environment variables which do this?
If you set GRIST_ORG_IN_PATH to false, Grist will attempt to extract a team from the domain name. You’d also want to carefully set the domain for cookies, using GRIST_SESSION_DOMAIN to .mydomain.com in your example if you want cookies shared across the teams. It would also be important NOT to set GRIST_SINGLE_ORG if you have been using that up until now.
You’ll also need to tweak your reverse proxy to deliver traffic to Grist for all the subdomains. I think Grist may also expect a docs subdomain to be available for personal sites (you can turn these off with GRIST_ANON_PLAYGROUND=false).
Just a heads-up: this configuration isn’t something we can offer a lot of support for, since by its nature it can be easily broken by configuration details outside of Grist.
