Hi there !
In a previous topic i managed (with generous help) to make an auto filler for my brewing sheets using action button and a separate table for recipes. Action button is fed data from a recipe and some other stuff (date, serial number, …) from some formulas.
It works great but now i’m facing a second problem : my database is not made in a healthy form as it includes a lot of empty columns. For example i have 15 “malts” columns, each neighbouring a mass column, a serial number column, and so on. I understand i should normalize this and have those be lines in a separate malt table, linked with a key to their own brews.
I’m slowly developing a solution to get to this format. Here is where i bump into problems : i like having the action button creating a new line for a new brew day but i cannot get it to work with keys in a reference column. See in this example that when creating a new brew, everything gets pasted in the right place, but the reference column does not work properly. Do you have any solution to circumvent this issue ?
